Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > C/K
Old 02-19-2016, 12:37 AM   #1
Jboof
1995 Chevrolet k1500 Transfer Case 4wd problem, Please HELP!!!
Alright, First off, thank you for any help. It is very appreciated!!
1995 Chevrolet k1500 Manual Transmission, floor shift 4wd 5.7 ltr.
I am having problems tracking down a wiring problem. It seems to be one thing after another. First a while back the front axle actuator wouldnt engage, so this past weekend I finally replaced it. I tried the 4wd and no luck. Next I check the fuse block and #24 slot (4wd) had a burnt fuse. Tried it again and blows fuse as soon as engaging 4wd and key in run position. From there read other forums to unplug and check front axle actuator again blows with out being plugged in. Moved back looking at TCase and checked Transfer Case Switch the same way doeant blow while unplugged. I replaced this switch just incase, with same results as before, fuse continues to blow.
Returned to reading forums and noticed there is another fuse for TCase at #2.....Found atleast one of my problems. This fuse slot is completely burnt out of the box. What can cause this? as far as tracing wires backwards from the box according to wire diagram and what colors should I be looking for?
My plan is to replace and pull those wires from the box and trace backwards hoping to find the short. And replacing fuse slot with a add in fuse link instead of replacing the IP fuse block. But still curious to the cause of the burnt slot. Could the actuator going bad have cause this?
Jboof is offline   Reply With Quote
Old 02-19-2016, 09:44 PM   #2
Schurkey
Re: 1995 Chevrolet k1500 Transfer Case 4wd problem, Please HELP!!!
Why did you start a duplicate thread just because you typed the wrong model year in the title of your first thread?
http://www.automotiveforums.com/vbul....php?t=1145744
All the answers to your wire harness questions are in the factory service manual. They're often available on eBay for pennies on the dollar.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Schurkey is offline   Reply With Quote
Tags
case , k1500 , transfer
