| Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here. |
1992 tbi v8 will only start when primed
I have a 1964 impala that I swapped out the drive train out of a 1992 1500 chevy truck. so I have the 350 with tbi and 700r4 trans. my problem is that it will not start unless primed but once I prime it it runs perfect. I can drive it around fine and it idles fine but once I turn it off it will not start. cranks fastbut no start. I can hear the pump going and when it starts cranking I can hear the pump stop. but it starts pumping agin while the car is running. so far ive replaced the fuel filter and completely rebuilt the throttle body.. while the body deff did need rebuild it still doing the same thing. is there something that is supposed to splash fuel into the body when start??? help a rider out please
Re: 1992 tbi v8 will only start when primed
one more note,,, this is not a new build. ive had this car running for 5 years so the problem is new. car has allways started good...
![]() heres a few pix of my car... |
search check valve they have both a 3/8 and 5/16 |
also on another note my brake light fuse blows every time I start the car. all the brakes work fine while in the on position and the fuse stays good while cranking but as soon as it fires up the fues pops. any ideas on ware to start and could the two issues be related? |
I drove the car to work today so if I need to snap any pix I can do that real quick no problem just let me no wat you need to see. just try n to dyi everything like I allways do. please help.
After the car is shut off for a 1/2 hour or more use a wrench and loosen the fuel line going to the throttle body. Does gas come out under pressure. Put rags under the fitting. I'll look when I go out to my garage today for a wiring diagram. |
