Go Back   Automotive Forums .com Car Chat > Oldsmobile > Silhouette
Old 02-26-2015, 02:37 PM   #1
72mino
2001 Olds silhouette, suspension compressor issues.
I am trying to fix my cousins van. The compressor won't run to air up the shocks or with the inflater on button. I pulled the relay from the wiring by the pump and jumped a couple of contacts and it runs fine and airs up the shocks. I pulled the jumper, the pump stopped and the exhaust solenoid let air out to drop it to the correct ride height. I didn't have my multi-meter with me so I couldn't test the relay properly, but I jumped power and ground to the correct terminals and it clicks, so I believe its working. I still swapped in the relay from my 99 that I need to take to the junk yard and it won't run.
What else could cause a known good pump to not run for the suspension or inflater?? I'm trying to save her some $$ and I have mine for parts, I'm just not sure what else to try.
Dustin
72mino is offline   Reply With Quote
Old 03-04-2015, 12:09 PM   #2
Tech II
Re: 2001 Olds silhouette, suspension compressor issues.
Either relay problem, level sensor problem, or wiring problem...
Old 03-06-2015, 04:02 PM   #3
sergeimoskva
sergeimoskva is offline   Reply With Quote
