| Register | FAQ | Social Groups | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1996 Cheyenne 3/4 Ton 4x4 Long box
I put a cap on the box and the inspection guy told me I had to have a Center High Mount Stop Light on the back of the cap itself (because the back of the truck cab has one). I mounted the fixture and routed the wires down the box post under the truck box (I included a plug connector before it goes down the box post, so I can unplug the cap easy when I want to remove it). Now I began to think ... I can't just tap into the brake light wire at the rear bumper because the CHMSL will come on too when a signal light comes on. Do I have to run a CHMSL feed from the fuse box or somewhere up front, all the way down to the rear bumper? Does someone know where to locate this feed, or do I have to reference a schematic in the manual? Guess what? I don't have the manual.While I was at it I installed a cargo light fixture inside the cap. I guess I could run that feed down from the front too while I am running the CHMSL wire. Am I looking at this right or does any body have some help ideas?
1923 Model T 'Stake' Truck, see in Legends of the Fall 1949 Chevy 3/4 Ton, had 214 ci now 235ci 1959 Dodge Mayfair 1986 Ford Ranger 4 cyl 1993 Pontiac TransSport 3.8 1996 Chevy 3/4 Ton 4x4 1999 Oldsmobile Alero 2004 BMW 330i Last edited by tinkering; 07-28-2014 at 11:02 AM. |
Re: Wire Center High Mount Stop Light?
If you don't have any absolute details, can you at least tell me if I am barking up the right tree?
1923 Model T 'Stake' Truck, see in Legends of the Fall 1949 Chevy 3/4 Ton, had 214 ci now 235ci 1959 Dodge Mayfair 1986 Ford Ranger 4 cyl 1993 Pontiac TransSport 3.8 1996 Chevy 3/4 Ton 4x4 1999 Oldsmobile Alero 2004 BMW 330i Last edited by tinkering; 07-28-2014 at 11:01 AM. |
Re: Wire Auxiliary High Middle Stoplight?
you tap the feed for the CHMSL at this fuse. then installing a 10A fuse in your new feed at this connection , then run wire to your CHMSL on the equipment you mounted . |
| The Following User Says Thank You to j cAT For This Useful Post: | ||
tinkering (07-28-2014)
Which fuse, the STOP/HAZ (Stoplamps) in the fuse box under the hood? That makes more sense to me than the fuse in the box under the dash Thanks j cAT .You have helped me once again. I just clicked you another 'Thanks'.
1923 Model T 'Stake' Truck, see in Legends of the Fall 1949 Chevy 3/4 Ton, had 214 ci now 235ci 1959 Dodge Mayfair 1986 Ford Ranger 4 cyl 1993 Pontiac TransSport 3.8 1996 Chevy 3/4 Ton 4x4 1999 Oldsmobile Alero 2004 BMW 330i Last edited by tinkering; 07-28-2014 at 11:07 AM. |
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
| The Following User Says Thank You to 777stickman For This Useful Post: | ||
1923 Model T 'Stake' Truck, see in Legends of the Fall 1949 Chevy 3/4 Ton, had 214 ci now 235ci 1959 Dodge Mayfair 1986 Ford Ranger 4 cyl 1993 Pontiac TransSport 3.8 1996 Chevy 3/4 Ton 4x4 1999 Oldsmobile Alero 2004 BMW 330i |
How do you contact a moderator? I want to correct the name of this thread to 'Wire Center High Mount Stop Light?'
A guy on the fullsizechevy.com forum gave me a wiring diagram indicating a CHMSL feed in the trailer bundle at the back of the truck. Here is the link: http://www.fullsizechevy.com/forum/g...ml#post5865948
Thank you all a bunch for your help.
