2001 Tahoe Air Inlet Valve Actuator
After turning the temp controls to full hot and then back to cold, the heat blows full hot and won't cool down during the trip. The rear AC works fine as long as the front AC is on (but running hot). I am told it is the Air Inlet Valve Actuator (AC Delco part number 15-72506). I am looking for advice to validate this and help location this part and replacing it.
Re: 2001 Tahoe Air Inlet Valve Actuator
Your air inlet actuator drives the door that decides the source of your air-- outside or inside the cabin..
Your issue is the temperature door actuator- does it move? is temp door stuck? remove actuator, see if it rotates 30 degrees or so- then see if you can move door. Your Tahoe is known to have temp door (or blend door) issues, as it has an aftermarket fix set up by our good friends at heater treater...does this description sound familiar? http://www.heatertreater.net/magento...hoe-00-12.html
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
#3 | ||
The temp door motor is binding on the door interface rod. I shimed the door motor module to have a space so that it will not bind / problem fixed. I guess when the ducting gets hot the plastic changes shape/size then it binds. post back if your successful. I used small washers .. |
