Go Back   Automotive Forums Car Chat > Dodge > Caravan | Voyager
Old 03-30-2014, 04:29 PM
venturenot venturenot is offline
change oil light will not reset Grand Caravan 2013
The change oil light on my 2013 will not reset. I have tried the routine advised in the manual - turning key to on/accessory and depressing the gas pedal slowly 3 times turning to off and then starting but it does not work. Any ideas?
Old 03-30-2014, 04:52 PM
aleekat aleekat is offline
Re: change oil light will not reset Grand Caravan 2013
Same procedure 07 buick. Takes several attempts before it will reset. Try going faster.
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
venturenot (03-30-2014)
Old 03-30-2014, 04:59 PM
Geez.. very frustrating. I have tried it about 10 times, sometimes slow sometimes quickly. I even removed the key after off position to see if that would work. Is there a sensor that could have gone bad?
Old 03-30-2014, 05:35 PM
Doubtful. Just did this yesterday, took over 10 tries to get mine to reset.
Old 03-30-2014, 07:56 PM
Thanks .. got it .. all is well.
Old 03-30-2014, 08:52 PM
Well the first time this happen to me, tried all day. Wife kept b****ing about the light. Friend stopped(mechanic) 1st try, it reset. Go figure. He did exactly what I had been trying.
Old 03-30-2014, 09:53 PM
I hate to admit it, but my mistake was that I thought that there were 3 key settings: Off --run/ accessory--start. I found out that there are actually 4 key settings. Off--accessory--on/ run--Start. It is real easy to move from the 2nd setting to 4th without even realizing the 3rd. Any way I found the 3rd setting and it worked the first time. So I guess all is well, and a new lesson learned.
Old 04-05-2014, 01:38 AM
Thomas Sams Thomas Sams is offline
Banned
To reset the oil change indicator system hope oil is not leaked,Turn the ignition switch to the ON position this also very helpful to you,Turn the ignition switch to the lock position..
