Go Back   Automotive Forums .com Car Chat > Mazda > RX-8
Old 03-24-2004, 04:33 PM   #1
Rxspeed
Send a message via AIM to Rxspeed
anyone seen this warning?
yesterday after work i got in my car and started driving home, when i noticed a yellow exclimation point was on in my left cirle gauge, (above the green light symbol) ive seen a symbol similar to this, but it was on my dads audi and that was for esp. knowing that this car did not have esp i took out my manual, and it says that this was a low tire pressure alert. when i got home i took out one of those little tire pressure gauges. and gauged all my tires. all of them read between 28-32. that sounds pretty normal to me, and i checked again this morning, and they all read the same. the alert remains tho, and im starting to get used to it, which isnt safe to get used to seeing an alert when something really bad happeneds. i got the car 4 weeks ago tomorrow, this isnt normal
has this happened to anyone else?
Rxspeed is offline   Reply With Quote
Old 02-20-2005, 09:40 PM   #2
Jahfari6
tire pressure warning
that is your tire pressure warning light. They are installed on the tires. I had the same thing happen to me. I'm not exactly sure what the right pressure should be, but I filled mine up to low 40's. The tires are rated to 51 psi, but you still want to keep the pressure well under.
Jahfari6 is offline   Reply With Quote
Old 03-07-2005, 06:29 PM   #3
kelrx8-civicbeater
Send a message via AIM to kelrx8-civicbeater
Re: anyone seen this warning?
cold temps can also throw it off
'91 CIVIC
'91 CIVIC SEDAN
'90 CRX SI -sold
'90 INTEGRA COUPE
'04 MAZDA RX8
Maido ST5 20x9 & 20x10
toyo proxes
kelrx8-civicbeater is offline   Reply With Quote
Old 03-30-2005, 10:32 AM   #4
nordicrx8
Yes, mine does that to adn seems to be when the tires are cold. When I get it out on the Autobahn, the light goes out.
nordicrx8 is offline   Reply With Quote
Old 10-04-2005, 08:24 PM   #5
KaylinSS999
I believe the Light also comes on if the pressure is too high.
KaylinSS999 is offline   Reply With Quote
Old 10-05-2005, 04:16 PM   #6
FDTT
Re: tire pressure warning
You need to lower your tire pressures.
Your tires shoudl be between 32-35 psi. No more than that.
Just because the tire is rated to 51psi does not indicate that the tire shodul be inflated near that. It is more dependant on the vehicle weight distribution. But inflating your tires to 40ish psi you are decreasing the contact patch that your tire makes on the road and therefor decreasing the grip your tires have ont he road.
Just a friendly reminder :P
Dont drive faster than your angels can fly
FDTT is offline   Reply With Quote
Old 11-14-2005, 04:03 PM   #7
mazdatekchubyninja
you need to have your tire pressure arount 32-35psi. the light will come on around 28psi. temp cause different reading(expanding+contracting of the air). if you keep driving with the tire light on it will affect your traction control and you have 1-2 more light come on DCS light. you might have a damage tire pressure sensor if you just had your tire changed. the sensor run around $300
mazdatekchubyninja is offline   Reply With Quote
Old 11-14-2005, 05:55 PM   #8
drftk1d
boost in, apex seals out
drftk1d's Avatar
Send a message via AIM to drftk1d
shit, at that price, i'd just remove the damn thing
RX-7 TII
drftk1d is offline   Reply With Quote
Old 11-15-2005, 10:32 AM   #9
mazdatekchubyninja
yeah but once your DCS OR TRACTION SYSTEM activate it cut power output. then all you have is one slow pos. sorry i just happened to drive one with that problem and it was night and day differance in performance.
Old 11-15-2005, 11:02 AM   #10
mazdatech177
i thought they already were one slow POS...
mazdatech177 is offline   Reply With Quote
Old 11-15-2005, 11:05 AM   #11
mazdatekchubyninja
yes master, sorry master you stand correct old wise one.
Old 11-15-2005, 11:21 AM   #12
mazdatech177
ahhh grasshopper... take this grain of rice from my hand before i can close it, then you will be prepared for the trials ahead
Old 11-15-2005, 11:24 AM   #13
mazdatekchubyninja
yes master, oh no not the valley of pos rx8, oh master i beg you no, may the force be with me. oh god send me a honda to face this evil, yet better send me a the blue devel vette.
Old 11-15-2005, 11:34 AM   #14
mazdatech177
no 'vette, no honda.... you will be armed only with a 1972 rx4 rotary wagon with an auto-meter monster tach(with shift light)
Old 11-23-2005, 02:58 PM   #15
mazdatech177
who in the hell is mazdaspeedninja. there could only be oneeeeeeeeeeeeee chubby ninja.
Anyone seen this message board? BurgerBoy '88 - '91 Civic | CRX | Wagon | Shuttlee 3 09-21-2002 04:29 AM
Has Anyone seen this truck Roadster2 Car Rumors & Concepts 9 06-23-2002 12:45 AM
Anyone seen this Before on Ebay? MSilage Engineering/Technical 2 05-27-2002 10:40 AM
german P10 anyone seen this one yet? ragt20 Cosmetics 16 09-05-2001 11:38 PM
