A/C Diagnostic and Troubleshooting - Help Needed
I am trying to tackle the job of repairing my A/C system in my 2002 Ford Windstar. Here is the information I have gathered so far:
1st Scenario - Pressure Test with engine off, nothing running: Low side pressure - 70psi High side pressure - 70psi 2nd scenario - I then started the engine, rolled windows down, set rpms at about 1800, and turned A/C on full blast and let run for 5-10 minutes. Here are my readings: Ambient Temp - 70f Vent Temp - 68f Low side pressure - slowly creeps up to 40psi, then compressor kicks on at 40 (for only one second) and pressure drops instantly to 20psi and compressor kicks back off High side pressure - stayed around 140psi, then shot up to about 150psi when compressor kicked on (again, only for a second) then back down to 140psi when compressor kicks off Note that the compressor only kicked on once every 10-15 seconds for only 1 or 2 seconds max 3rd Scenario - I "jumped" the low pressure switch forcing the compressor on and let run same as scenario 2 for about 10 mins, here are the readings: Ambient Temp - 70f Vent Temp - 70f Low side pressure - negative 10psi High side pressure - 210psi My understanding is that if low side goes negative and high side is high, then the problem is a clogged evaporator core and possibly clogged expansion valve as well. Can anyone confirm this? I am ruling out the compressor because it is clearly compressing or else it wouldn't be able to draw negative pressure on the low side. Also, this van had rear A/C. Does it have a seperate rear evaporator core and expansion valve? Any information would be greatly appreciated. Thanks, Nick |
Re: A/C Diagnostic and Troubleshooting - Help Needed
To me it reads as you are very low in refrigerant.
You've lost about 85% of your necessary refrigerant. Recover- fix leak and evac and recharge to factory spec- and then it should work.
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
