Old 08-15-2012, 04:14 PM   #1
bluebirdj
Driving while blind
My very mature senior mother is unwilling to curtail driving after dark, when she cannot see. I do not want to remove her car from her, but....
Is anyone aware of a device that can disable ignition function during the hours of darkness? If not, would someone care to design one....?
Thanks
bluebirdj is offline   Reply With Quote
Old 08-15-2012, 10:52 PM   #2
shorod
SHO No Mo
shorod's Avatar
Re: Driving while blind
The design should be pretty simple, a relay, photocell, op amp IC set up as a comparator with hysteresis. You could wire up the relay as a starter disable, or if you're concerned she may start the car before dark and leave it running, then you could install the relay on the fuel pump (assuming a modern fuel injected vehicle). If she parks in a garage or brightly lit parking area, you probably wouldn't want the starter disable, but you'd need to be careful with the fuel pump route as having a car stall while driving (assuming she were still driving it after sundown, or a storm rolls in) could be a safety issue. Therefore you'd want a warning buzzer or something that would sound before the fuel were cut.
Maybe the simplest approach, and most difficult to defeat, would be to wire a relay in to the fuel pump circuit that opens when the headlights are turned on. Assuming the car has manually operated headlights, the safety concerns would be precluded as long as she is aware the device is installed. As it starts to get dark she'll know if she turns the headlights on the car will stall, giving her plenty of time (in theory) to pull off and park the car in a safe area. Of course it could also encourage her to drive without headlights.... You'd also want to have a sticker in the car that would make the feature known to anyone else who may borrow the car.
-Rod
Old 08-30-2012, 09:33 AM   #3
Joseph812
People, don't forget about the importance of a clean windshield.
Joseph812 is offline   Reply With Quote
Old 08-30-2012, 01:46 PM   #4
shorod
SHO No Mo
shorod's Avatar
Hunh? How does this relate to the thread?
-Rod
Old 08-30-2012, 02:12 PM   #5
Blt2Lst
Blt2Lst's Avatar
-Rod
A clean windshield does make it easier to see at night especially with headlights coming at you and clean side windows help to see what's in the mirrors clearer.
Maybe it's just an age thing, it didn't bother me as much when I was younger but now it does and I am not even that old yet, or so I think.
Just my
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Blt2Lst is offline   Reply With Quote
Tags
darkness , disable , ignition , seniors , visibility
