Go Back   Automotive Forums .com Car Chat > Oldsmobile > Intrigue
Old 03-11-2012, 01:46 PM   #1
greasyhog
AF Premium User
P0442 SMall EVAP leak
So I have had this code P0442 for a long time and I just kept clearing it. Just went out to find the leak and found it and thought maybe it may help someone else. The attached picture (at an angle) shows the hole in the small line attached to the fuel neck filler exactly behind where the plastic wheel well cover touches it. Just ordered a new one from rockauto for about 65 shipped.
greasyhog is offline   Reply With Quote
Old 03-11-2012, 02:25 PM   #2
Tech II
Re: P0442 SMall EVAP leak
Yeah, when you have a small leak, it's usually the cap......but it could also be any number of things.....sometimes you get lucky during a visual inspection(have replaced a lot of fillpipes up here in the northeast), and sometimes only a smoke test will point it out....
Old 03-22-2012, 08:09 PM   #3
brian_k24
I had the same issue and replaced the gas tank filler neck, looked similar to yours. Did not solve the problem, I had to also replace the o-rings on the vacuum lines at the purge valve solenoid.
brian_k24 is offline   Reply With Quote
Old 07-24-2012, 06:49 PM   #4
pfofit
Greasyhog? Or anyone else that has changed the filler neck on an intrigue.
How did you make out with the aftermarket filler neck from Rockauto?
Did you get the Dorman or Spectra part and how well did it fit / line up.
Thanks
If it was easy, then anyone could do it.
pfofit is offline   Reply With Quote
The Following User Says Thank You to pfofit For This Useful Post:
danielsatur (08-28-2012)
Old 08-02-2012, 05:12 PM   #5
greasyhog
AF Premium User
I got the Spectra and it fit perfect.
Old 08-28-2012, 04:57 PM   #6
pfofit
Gas started dripping bad when filling up, so had to bite the bullet.
Had an evap code P0442 on and off for a year or so.
Replaced filler neck with a spectra FN717, fit was fine. Had trouble getting a 3/4 inch broken off bit of vent pipe out of the plastic vent line from the tank. Patience and a bit of lube.
Can you spot the defect?. Why Car makers make safety items like fuel and brake lines out of material that disintegrates before all else is beyond me?
97 Ford Expedition CE light Large Evap leak ptclink Expedition 11 04-07-2006 03:47 AM
2000 Suburban Misfire, Lean, Evap Leak fatpigdog Suburban 1 03-28-2006 06:59 PM
evap leak parts68 Aurora 0 03-11-2006 10:24 PM
engine light..small evap leak Bruski Bonneville 1 11-24-2004 02:34 PM
EVAP leak code after sending unit replacement autoauthority Caravan | Voyager 1 08-01-2004 11:22 AM
