Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 09-15-2011, 11:53 AM
96DEVILLE 96DEVILLE is offline
01 deville
I have a 01 deville the front valve cover gasket is leaking oil. Is it hard to change gasket.
Old 09-15-2011, 12:24 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 01 deville
There is a fair amount of dissasembly involved, including needing the correct puller to remove the water pump drive pully, also the camshaft seal behind the pully will need to be replaced. Sometimes that pully can be a real bear to pull off.
I recomend looking at a manual and reviewing the process to see if it is something you will feel comfortable with.
Good luck!
e 30 isc 90 caddy deville chris90deville Deville 0 03-26-2010 02:50 AM
Engine Coolant and Heater on a 1990 Cadillac DeVille? butturinij@uwplatt Deville 2 11-03-2009 10:04 PM
1988 Sedan Deville inside fan problem Matt137 Deville 1 09-25-2009 11:15 PM
Could i use a 1994 caddie deville sor a parts car for my 1995 deville e.burns666 Deville 1 05-02-2009 10:47 PM
1985 Cadillac Deville 4.1 liter into 1987 Deville Sammy64 Deville 3 12-26-2003 01:05 PM
