Go Back   Automotive Forums .com Car Chat > Ford > Taurus | Taurus Wagon
Old 08-29-2011, 07:54 PM   #1
1534dover
Additive for coolant leak
my 1995 Ford Taurus has a coolant leak. Is there a way to fix it without tearing the engine apart? About an eighth of a cup a day. Will GM Pills help this?
1534dover is offline   Reply With Quote
Old 08-29-2011, 08:02 PM   #2
Moppie
Master Connector
Moppie's Avatar
Re: Additive for coolant leak
If you don't care about the car and have no long term plans for it, then there are plenty of different stop leak products that might, or might not work.
But, these products work by solidifying in the cooling system where is a leak to air, or a change in pressure.
They can often block critical passages in the engine and cause over heating problems in the future.
Can you see where the leak is?
Usually they are not that hard to fix, and long term it is always the better solution.
Moppie is offline   Reply With Quote
Old 08-29-2011, 11:59 PM   #3
1534dover
My mechanic says it is the gasket in a housing that would require three to four hours labor to remove if they didn't break any bolts in the process. Their experience is Ford bolts here often do break no matter how careful they are.
Old 08-31-2011, 02:38 PM   #4
Willyum
I wouldn't use anything unless it was a radiator leak in the metal. I once used just egg white that worked well for that.
For the engine you need to get serious.
Willyum is offline   Reply With Quote
Old 09-01-2011, 12:24 AM   #5
1534dover
I used one AC Delco Cooling System seal tab, apparently a fiber product. And one I think will do the job.
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 05:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 08:53 AM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 11:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 05:17 PM
Oil Additives for Slowing Leaks ihgrad Camry/Camry Hybrid/Vista 8 06-23-2008 09:45 PM
