Go Back   Automotive Forums Car Chat > Chevrolet > Astro > M Bodies
Old 11-19-2011, 06:06 AM
blpogue blpogue is offline
95 Astro starts with starting fluid and speed up when put in gear
Hi all, newbie here:
My Astro started doing weird thing a couple of days ago, started and ran fine then I noticed when I engaged it in gear the RPM goes up drastically (500+ rpm) so bad you had to keep foot on break to keep it from lunging ahead. Also did this in any other gear. But shift back to park or neutral and it idle's back down to normal. Then yesterday it will only start with starting fluid. Checked pressure and with key turned it goes to 58psi, it jumps to 62psi while cranking. Shut key off and it holds at 58psi. After getting it started with a shot of either, is holds at 58psi. Does anybody have any ideas? Sorry for long post but wanted to make sure I got it right. BP
97 Suburban won't start, runs with starting fluid rtalnadge Suburban 6 08-30-2014 05:15 AM
2000 GMC Sonoma Will Not Start Without Starting Fluid aserapiglia General Discussion 10 01-29-2011 11:27 AM
01 blazer only starts with starter fluid showmysebringlxi Problem Diagnosis 2 04-03-2009 10:34 AM
01 s-10 only starts with starter fluid lawspot101 S-10 2 10-16-2008 09:34 AM
95 Astro only starts with starting fluid zjb M Bodies 3 01-16-2007 04:35 PM
