Go Back   Automotive Forums Car Chat > Dodge > Caravan | Voyager
Old 12-28-2010, 07:53 PM
coward13 coward13 is offline
Exclamation coolant leak
thought it was the water pump - no it's not. Coolant appears in the area just above the lower radiator hose where it attaches to pump housing. Drop forms every 10 to 15 minutes. Looks like it is seeping from the gasket between the chain case cover (lower radiator hose connection appears to be part of this cover?). There is a sensor there, but that is not the source of the leak either.Could this be a head gasket leak or a gasket failure on the chain case cover? I can't find anything in the way of a diagram of how this stuff fits together.
Old 12-28-2010, 08:39 PM
tempfixit tempfixit is offline
Re: coolant leak
What year, engine, mileage
Old 12-28-2010, 11:51 PM
Re: coolant leak
1999, 120k
Re: coolant leak
whoops, 3.3 L
Old 12-30-2010, 04:28 PM
Re: coolant leak
It has been some time since i worked on these vans and they have been 95's or older but it seems to me there is a hose from the top of timing chain housing to the intake on these that may leak and follow the housing cover. Worth looking at hose and clamps.
Old 12-31-2010, 01:21 PM
tommyvjr tommyvjr is offline
Re: coolant leak
i got the same problem 1996 3.3L grand caravan, can't find the leak, it leaks only when the van is park,not while its running, and the leak is by the belt ,hose, that side.(small puddle amount of anti freeze)
my 96 g caravan wipers stop in the middle of the operation. ive been having trouble lately, they work and they dont work. any input?
Old 06-17-2011, 12:17 AM
plodder's Avatar
plodder plodder is offline
Re: coolant leak
I have a coolant leak also in my 2000 chrysler voyager 3.3, It seems to leak in much the same way. when stopped, intermittent drip just above the oil filter about 5 or six inches, it runs down a hose and drips off the bend in the hose. I was wondering if using the wrong coolant could create some kind of a seal problem. I heard this van takes a special red coolant that should be bought from the dealer (HOAT). Does anyone know anything about the coolant type to use on my van or its non dealer substitute? Would the wrong coolant cause a leak possibly or would mixing the coolants create a problem?
Hope is the destination that we seek.
Love is the road that leads to hope.
Courage is the motor that drives us.
We travel out of darkness into faith.
Book Of Counted Sarrows
Old 06-17-2011, 04:27 PM
Bear Bear is offline
Re: coolant leak
Check the coolant bypass hose (the one that bypasses the thermostat until thermostat opens) these are infamous leakers as the car ages.
Old 06-21-2011, 02:20 PM
mishalah's Avatar
mishalah mishalah is offline
Re: coolant leak
And be sure it's coolant and not a/c condensation combined with a little road grime dripping after you've used the a/c.
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 05:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 08:53 AM
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 07:43 PM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 11:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 05:17 PM
