98 Lumina intake or head Gasket
I have a 98 lumina 3.1 I replaced the themostat and water pump. Everything was woking fine with heater working. today I cant get no heat and is running a little high on temp until the thermo kicks in. I noticed what could be coolant with the oil not alot but I can see notice it. Now what gasket could of went south. intake or head. or both. Kinda of sucks because everything was working fine yesterday just like it should. Have a Save new year.
Re: 98 Lumina intake or head Gasket
if your lower intake gasket went out, air (when engine is cooling) and oil could enter the coolant and the air reacts with dexcool to create sludge which then could clog your heater core. are you still running dexcool and do you see any sludge in your coolant reservoir?
1999 Dodge Ram 1500 2WD 5.2L NV3500 1998 Chevy Lumina 3.1L (2010 DIY intake/head job, 2011 DIY A/C replaced, ran like a top til I sold it in 2014) 1999 GMC Sierra 4.3L 2014 Toyota Prius Four |
see http://www.steelseal.com , or blue devil.
Well I plan on starting the intake gasket next week. The heater blows plenty of hot air when I have the coolant level where it needs to be. I for sure have a coolant leak that is going on. car runs fine other than the coolant leak. Milky and and way to much mixture when I check the oil dip stick. My only question is how can you tell if its a LMG or head gasket that is bad. Gary
#5 | ||
If i were u, I'd pull the lower intake manifold and check the gasket. You should be able to see if it has deteriozed enough to leak instead of just a tore up gasket from the removal of the lim. IF the gasket's look good then go for the head gasket's and check the head's for warpage. If warped, get them resurfaced. That's what i would do. C-ya Scott
#7 | |
definitely get the steel LIM gasket, felpro sells both plastic and steel but i'd avoid plastic again... along with dexcool - just doesn't do too well when you get air in the coolant passages
i forget which, i think the instructions with felpro head bolts (or maybe headgasket), they tell you to follow their instructions, not OEM factory manual instructions... something like 80ft/lb + 90 degrees have someone mark off a diagram of the head bolts so you dont miss a 80ft/lb torque or miss a 90 degree turn, i forgot at one point where i was, so threw out a head gasket and set of bolts
#8 | |
Just completed mine, 90% probability it's the LIM gasket. I've read on one of the forums that you can check for head gasket by checking the sparks, if the spark head is not milky, it's not the heads. Here are some links I found, they will be useful to you:
http://hubpages.com/hub/Chevy-31-Lit...d-Warped-Heads http://www.garagejournal.com/forum/s...0677&showall=1 http://www.autoforumz.com/99-Lumina-...ict229025.html http://www.freeautoanswers.com/intakemanifold.html http://www.garagejournal.com/forum/s...ad.php?t=39862 http://www.zrxoa.org/forums/showthread.php?t=245429 http://www.w-body.com/showthread.php...ictures)/page3
1996 Lumina 3.1 - 191K 2001 LeSabre Custom - 153K 2006 Explorer 4.0 - 55K |
