Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Problem Diagnosis
Register FAQ Social Groups
Old 02-06-2011, 05:11 PM
c.martin13 c.martin13 is offline
1995 jimmy transmission problem
1 have a 1995 jimmy with a 4.3 4x4 in it. I was plowing the other night and all of a sudden the transmisission is slipping in it.if a am at low speeds and from take off it is okay, but after getting up some speed like 50-70 Kilometers it justs revs up high and hardly works when pressing on the gas until you let off on it, it seems to be like a problem with the passing gear, I had no worning leeding up to this problem, any help would be great, thanks
Old 02-07-2011, 07:07 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1995 jimmy transmission problem
Snow plowing or getting stuck in the snow does things like that.
It sounds like it is done for.
Is it is full of fluid and fluid not burnt?
You need to get it on a transmission capable scanner and check it out.
Check for codes and check the slippage readings and shift times.
Post back what the scanner shows.
Also drop pan and check filter and for metal/and or clutch stuff in bottom of pan.
Let us know what you find.
MT
1995 Jimmy misfires when cold reed92 Problem Diagnosis 11 01-17-2010 10:32 AM
1995 jimmy 4x4 problems c.martin13 Jimmy 3 12-23-2009 04:51 PM
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 04:49 PM
1995 jimmy transmission and possible motor change?? getoverit66 Problem Diagnosis 1 08-04-2007 08:55 PM
1995 jimmy transmission jcheinl Problem Diagnosis 1 12-14-2006 09:48 AM
