Go Back   Automotive Forums .com Car Chat > Chrysler > General Discussion
Old 01-16-2011, 09:21 PM   #1
tboyadjian
Rear passanger brake running hot
Hi,
I recently did a brake job on my 2000 Cirrus (replaced wheel cylinder, pads, hardware kit, and drums turned), and sometimes the rear passanger brake is running hot (very inconsistently - it will do it one day and not the next). I opened it up twice and inspected - everything has been assembled correctly and the adjusters are greased and move nicely. It worked very well for a while, and then I smelled it and noticed it was running hot. The feel of the brakes is very good: pedal is right up and there is no significant braking bias (in either the fronts or the rears) when you hit the brakes hard. Any idea's?
Some interesting things that I did notice:
- when I did the brake job, the rear pass wheel cylinder had been leaking, so it was really gummy inside. This is one reason I had the drums turned. I measured the drums and they are in spec.
- it was significantly harder to bleed the rear pass then any of the other wheels, including the rear driver side.
Help me out if you can. Thanks.
tboyadjian is offline   Reply With Quote
