Register FAQ Social Groups
Old 05-18-2003, 10:08 PM
99civic03's Avatar
99civic03 99civic03 is offline
Send a message via AIM to 99civic03
AEM V2 Intake
I am looking in to purchasing a cold air intake for my 99 Civic EX, and I cant decide between the original AEM CAI or the V2. How would the horsepower and torque gains vary between the two? Can anyone give me actual dynoed numbers from these intakes? Do you think it would be worth it to spend the extra $80 and get the V2?
Another question I had was will I have to mess with the ECU at all because of the larger amount of air in the engine? I already have an exhaust, so i dunno if that matters any either. Also, could I install this myself? or should I get a professional to do it?
Old 05-18-2003, 10:43 PM
ssshhhh (_burn_)'s Avatar
ssshhhh (_burn_) ssshhhh (_burn_) is offline
Send a message via AIM to ssshhhh (_burn_)
Re: AEM V2 Intake
get an iceman cai and cut it before it bends down and run a good filter. or take your stock intake tube and do one of the following...
1. cut the airbox off and take a peice of pantyhose and double it over wrap it over the end of the tube and clamp it down....and NO nothing harmful will get ate up by your motor because of the filter being pantyhose. and wrap the stock tube in heat resisting tape
2. keep the airbox but cut all plastic attatchments and cut out the face of it (facing out of the engine bay). then if you do it right, use the money you saved from the aem and buy a k&n drop-in filter and install that. and wrap the stock tube in heat resisting tape
you should get a little better throttle responce with the second. those three intakes will give your better lowend torque and just about equal power up in rpms as the aem.
another tip: find a way to plumb cold air from the bottom of your bumper up near the filter via a peice of plastic flexpipe (like whats on the back of your washing machine)
and no you probably wont HAVE to mess with your ecu just for intake and exausht. if you have a fpr you might get more gain if you turn your fuel pressure up like 2 psi.
6.7 @ 211mph whooping kubo's ass all over the track
Old 05-18-2003, 10:44 PM
Re: Re: AEM V2 Intake
you should spend the money from the intake and get you a good header.
Old 05-19-2003, 12:06 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
umm, dont use any kind of clothing to make an air filter out of. there are small particles that will pass through and eat away at your motor.
even if you get just some knockoff intake off ebay for 60bux, it will be alot better than just a drop in filter, or the stock airbox.
Stable Of Cars I have Owned:
1991 Honda CRX
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-19-2003, 12:29 AM
99civic03's Avatar
I did a little more researching and decided Im just gonna go with the original AEM. How much hp and torque would u expect me to gain from this mod?
Old 05-19-2003, 06:47 AM
then those guys over in japan running itr's on the circuit are just dumb arent they?
Old 05-19-2003, 12:26 PM
crxlvr's Avatar
no there not, but im sure he doesnt care how hot the damn intake is gonna get to worry about the 1-2hp drop after it does, hes not a circuit racer.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-19-2003, 08:02 PM
neunan neunan is offline
Send a message via AIM to neunan
umm...unless you dont have a job or any source of income you might wanna ignore shhh_burn. i have the AEM CAI and i love it, but i never dyno'd. i know from dynos that this intake gets 20.7 hp for the RSX-S and i think about 9 ft. lbs. of torque. but the K20 is a pretty damn good engine. id expect around 12 hp and maybe 6 ft.lbs of torque...and if anybody has corrections on that, feel free.
also, re: the ecu, i dont think you have to do anything to it, but i heard theres a fuse you can disconnect for 2 minutes and put back in and it will recalibrate itself...but i dont remember which one it is so maybe somebody else can fill that in
96 Accord EX 5spd coupe - black
AEM cai * DC Sports cc 4-2-1 header * GReddy EVO catback* AEM trupower pullies * ACT HDSS clutch kit * ClutchMasters 8lb flywheel * NGK blue wires * 4 wheel Brembo slotted rotors with AEM pads * 4bidden Motorsports shortshifter
pioneer deh9300 * phoenix gold zero point wiring * blaupunkt pa2100 pushing diamond audio HEX 6.5 comps in front * blaupunkt pa275 pushing power acoustik fahrenheit 6x9s in back* 5" LCD TV * 8-bit original NES
Old 05-19-2003, 08:09 PM
BUT - we rigged a k&n style air filter with some 3" PVC piping into my friend's 92 civic hb and he got some amazing gains... im sure an AEM would blow that away, but theres a good low budget alternative. not to diss shh_burn but i dont trust pantyhose in my engine compartment, or anywhere else in the functional areas in my car
Old 05-19-2003, 08:20 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
guys...a CAI isn't going to show any bigger gains then MAYBE 4-6 hp TOPS. jus cuz its SAYS 10-20hp, doesn't mean thats' to the wheels or on a stock motor.
as for the k20a3, the gains from i/h/e were around 20hp, NOT jus for a CAI. those motor's love the simple bolts for some reason...(prolly cuz of I-VTEC) but...on a SOHC VTEC motor, u'll see minimal gains.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 05-19-2003, 08:21 PM
yeh.....i make alot of money and i would never dump an once of it into an aem cold air intake. your post was ignorant. i gave the best solution to his problem (unless of course he cares that much about how a cai looks under his hood) i ran a stock itr plastic intake tube with a peice of pantyhose on the end when i was running my allmotor setup and that car ran high 12's at the track with that intake.
WTF. you can not compare power gains from an rsx-s to a 99 civic ex... your NEVER going to see gains like that from an ex. EVER.
Old 05-19-2003, 09:03 PM
TheRebirth TheRebirth is offline
Banned
20hp from the intake alone...rofl
...i wish
Old 05-19-2003, 10:45 PM
the rsx's seriously do get that type of power lol
Old 05-19-2003, 11:35 PM
liquid8 liquid8 is offline
Send a message via AIM to liquid8
those numbers where in an issue of import tuner.
"life's a bitch but god forbid the bitch divorce me" - nas
Old 05-20-2003, 03:02 AM
YOUNGSTER YOUNGSTER is offline
Send a message via AIM to YOUNGSTER Send a message via MSN to YOUNGSTER Send a message via Yahoo to YOUNGSTER
actually they tested the v2 and compared it to the old school aem cai. its made i think in between 6-8 hp and 2-4 lbs. trq. on a sohc vtec im pretty sure a 98 ex.
