98 caravan ac stuck in defrost position
my 98 caravan ac sytem is stuck in defrost position turn the mode dial and nothing changes i got a code 1 and 3 out of the climate control module. 1 states stuck in defrost and 3 says passenger blend did not reach cold stop. what does this mean and how can i fix it?
Re: 98 caravan ac stuck in defrost position
I take it the calibration test isn't helping. Inspect the connection on the panel. They are known to melt on 3rd generation vans. Defrost is the default mode when the processor looses power or programming. Try disconnecting the negative battery cable for 2-3 minutes to reset it. Can't help beyond that. Maybe a new panel - Ebay? Hope someone with a factory manual can jump in here.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
I'm not familiar with the system but here is what the FSM says, maybe someone with more knowledge can help:
DIAGNOSTIC TROUBLE CODE 1 - MODE ACTUATOR DID NOT REACH “DEFROST” POSITION DESCRIPTION When the HVAC Control Module calibrates the Mode Door Actuator, it first moves the actuator toward the DEFROST position. In the DEFROST position, circuit C37 of the 21 pin connector should have a value of approximately 0.3 to 0.8 volts. When the actuator does not reach the DEFROST position, DTC 1 sets. DETECTION When the voltage at C37 is approximately 2 volts or greater, the DRB IIIt will display the DTC. POSSIBLE CAUSES • Mode Door reaches the DEFROST position and does not respond to changes in the control panel settings. • Mode Door Feedback Signal circuit is OPEN. • Mode Door Feedback Signal circuit is SHORTED to 5 or 12 volts. • Mode Door is stuck. • Mode Door Actuator is stuck. • Mode Door Driver circuit is OPEN. • Mode Door Driver Circuit is SHORTED to ground. Diagnostics begin momentarily and then STOP with no LED’s until the short is removed, and then both WIPE and INTERMITTENT LED’s flash simultaneously. • Mode Door Actuator gear is not properly connected. • Sensor ground circuit OPEN may set multiple DTC’s 1, 4, 5, and 8, and defaults to Full Hot and Defrost. Recirc continues to operate. If there is air flow in the Defrost position, even though the DTC indicates that the actuator cannot reach the Defrost position, there is and open in the Mode Door Feedback Signal circuit (the door is moved to the Defrost position attempting to lower the feedback voltage). If the Mode Door Actuator fails between Bi-Level and Mix, both DTC’s 1 and 2 will be set. If the Mode Door Actuator fails in the Panel Position and is blowing air in this position, DTC 1 is set. TEST PROCEDURES Disconnect the Actuator connector. (1) Using a voltmeter, measure between pins 1 and 5. If the voltage is not 12 volts 6 1 volt, check the actuator driver circuits wiring for a short or open circuit. Measure the voltage between pins 2 and 4. If the voltage is less than 4 volts, check the 5 volt supply circuit. Measure the voltage between pins 3 and 4. If the voltage is less than 4.5 volts, check the actuator feedback circuit. (2) Remove actuator, and check if the gear pins are in the correct track on cam or if they are binding. If OK, go to Step 3. If not OK, repair as necessary. (3) Check for binding door, if door is binding repair as necessary. If gears and door are OK, replace actuator. (4) Once repairs are completed repeat the Calibration Diagnostic and Cooldown test. Repeating the test is necessary to clear the fault codes. DIAGNOSTIC TROUBLE CODE 3 - BLEND/ PASSENGER ACTUATOR DID NOT REACH “COLD” STOP DESCRIPTION When the HVAC Control Module calibrates the Blend/Passenger Door Actuator, it moves the actuator toward the HOT position and then toward the COOL position. In the COOL position, circuit C36 of the 21 pin connector should have a value of approximately 0.6 to 1.2 volts. When the actuator does not reach the COOL position, DTC 3 sets. DETECTION When the voltage at C36 is greater than 2.0 volts, the DRB IIIt will display the DTC. POSSIBLE CAUSES • Blend/Passenger Door reaches the COOL position and does not respond to changes in control panel settings. • Blend/Passenger Feedback Signal circuit is SHORTED to 5 volts. • Blend/Passenger Actuator is stuck. • Blend/Passenger Door is stuck. • Blend/Passenger Door Actuator Driver circuit is OPEN. • Blend/Passenger Door Actuator Drover circuit is SHORTED to ground. Diagnostics begin momentarily and then STOP with NO LED’s until the short is removed, and then both WIPE and INTERMITTENT LED’s flash simultaneously. • Battery Voltage is less than 10.0 volts. If there is air flow (passenger side on Zone control),, even though the DTC indicates that the actuator cannot reach the cool position, there is a short to voltage in the Blend/Passenger Door Feedback Signal circuit (the door is moved to the Cool position, attempting to decrease the feedback voltage). If the Blend/Passenger actuator fails in the Mid position, both DTC’s 3 and 4 will be set. If the Blend/Passenger Door/Actuator fails in the Hot position and is blowing hot air, DTC 3 is set. TEST PROCEDURES (1) Check if the correct HVAC control module was used. Disconnect the Actuator connector. (2) Using a voltmeter, measure between pins 1 and 5. If the voltage is not 12 volts 6 1 volt, check the actuator driver circuits wiring for a short or open circuit. Measure the voltage between pins 2 and 4. If the voltage is less than 4 volts, check the 5 volt supply circuit. Measure the voltage between pins 3 and 4. If the voltage is less than 4.5 volts, check the actuator feedback circuit. (3) Remove actuator, and check if gear pins are in the correct cam track or binding. If OK, go to Step 4. If not OK, repair as necessary. (4) Check for binding door, if door is binding repair as necessary. If gears and door are OK, replace actuator. (5) Once repairs are completed repeat the Calibration Diagnostic and Cooldown test. Repeating the test is necessary to clear the fault codes. Mike |
Mike - Big thank you. That's one of the few time someone actually did "jump in" with a factory manual and I've been on forums for years.
No, thank you RIP for all the help you have given to others. I've only had my van since May and have been fortunate that so far it has no troubles. But I read every forum dealing with third generation vans just to expand my limited knowledge.
Mike |
