Brake Caliper Bolts
Title should be Brake Caliper BRACKET bolts.
When you replace brake disks and have to remove the caliper mounting bracket, on installation,,do you use a thread locker on the bracket bolts if you are reusing the same bolts? I have read some say you should, and other say thread locker is not needed, just torque to specs. Thoughts and recommendations please and thanks. |
Re: Brake Caliper Bolts
When I replaced the disks on my '97, several years ago, I don't believe I used a thread locker. Also, I am fairly sure I did not torque the bolts to specs either. I drive some fairly rough back roads and never lost a bolt. I used to have a Taurus that would occasionally loose the bolts that the calipers slide on. I ended up using a locker on those. There just wasn't enough thread for a good grip.
Thanks for both replies. So I guess it is 50% against using it and 50% for using the thread locker. I have removed the caliper brackets several times before on various cars over the years, and have never used an thread lock on the bolts, and never had any loose bolts. So, I probably will not bother this time either.
Thanks. |
I noticed that thread locker is used originally on caliper bolts, but I've never bothered to use it myself, nor have I ever torqued them. I just torque them as much as I can with my 15" ratchet. However, given that thread locker is quite cheap, and I have a tube of it now, it's probably not a bad idea to use it. For bleeder valves I torque them, then test the system for leaks. Then I torque them just enough so that it doesn't leak.
Thanks everyone.
