Go Back   Automotive Forums .com Car Chat > Opel/Vauxhall > Commodore/VS/VT/VX
Old 03-05-2006, 04:29 AM   #1
robbojr
Exclamation VR burnouts
I recently got a 1994 VR commodore thats only done 130,000K's in top condition but its an automatic. When i go around corners and floor it the back does not slide out much at all and i seem to have a flat spot because when i put my foot down it doesent accelerate as fast as i want it just revs and dosent go anywhere untill it kicks into gear and by that stage im already around the corner and down the street. any idea's? anyone else with a VR commdore having the same problem or any technique to drifing? cheers
robbojr is offline   Reply With Quote
Old 03-06-2006, 08:39 PM   #2
pgc
Re: VR burnouts
That's typical of a VR auto. I had one, and the only way to get it sliding was to put it into second before you get to the corner, point the noise at the apex (before the corner) and floor it. It will understeer for a second, but then the back end will start to come around. You need to be going at least 40km/h for it to work.....
Good luck and don't get caught!
pgc is offline   Reply With Quote
Old 12-03-2006, 02:33 AM   #3
[PSI-EFI]
[PSI-EFI]'s Avatar
Re: VR burnouts
is it a 6 or 8. is ur diff an open wheeler or LSD. put a shift kit in it, put a minispool and when u go around a corner, floor it and watch it go sideways. when its wet, be carefull because trust me, it will slide.
BTW, wen u go around the corner, leave it in first, rev it hard till its near redline or on it, then shift to second, floor it and then put it in drive.
not every 13 yr old knows how to do burnouts so just ask around and try what i said.
if not, wack a 355 stroker and hang it. [PSI-EFI]
[PSI-EFI] is offline   Reply With Quote
Old 12-15-2006, 11:25 AM   #4
bman575
Re: VR burnouts
hey mate first off it a vr commie nt realli built for drifting and sum models have abs witch actually stops sliding but aside from that basicly when you start to cum up to the corner drop it in first and ful turn the wheel example turning right ful hook right then left straight afta aka fishies if that ya style of drifting or just sit on teh brake works for me :-)
bman575 is offline   Reply With Quote
Old 03-04-2007, 10:29 PM   #5
EvilSpeed
Re: VR burnouts
Get some old window squirters hook them up to squirt your rear tires with a liquid of your choice...fang it!
EvilSpeed is offline   Reply With Quote
Old 06-03-2007, 05:39 AM   #6
my-vr-v8-manual
Re: VR burnouts
hey buddy i have a vr v8 manual 5l i think i know y u r having problems. 4 one it is a 6 so go and get an 8 and 2 its an auto u need a manual. hope u figure it out man also what does ya car look like. im looking for people who have vrs want to do a drive out .
chers buddy
my-vr-v8-manual is offline   Reply With Quote
Old 05-09-2008, 10:22 AM   #7
jared2286
Re: VR burnouts
u could put a stall converter in it...watch her rev and wait for the power to hit. or get on the brake and skid it round the corner....
345 rwhp unopened ls1... more coming!!!
jared2286 is offline   Reply With Quote
Old 12-23-2009, 07:10 AM   #8
driffter
Re: VR burnouts
lion locker and mini spool for ultimate burnouts on any rear wheel drive car
driffter is offline   Reply With Quote
