Go Back   Automotive Forums .com Car Chat > Pontiac > Trans Sport
Old 05-01-2010, 04:54 PM   #1
A10ECGent
Needle bearing in oil pan
Ok I have had a low oil pressure problem for a while in my 95 3800 transport. I started it the other day and it started knocking I still had oil pressure though so I decided today to pull it down and replace bearings. The main and rod bearings showed what wear I would expect for 200,000 miles the problem is I found needle bearing in the oil pan and I'm not sure where they came from. Anybody got any ideas I assume the cam and balance shaft are babbit and the roller lifters are solid rollers I pulled a valve coverto see if they could be rocker bearings but they are not as wide as what I found
Thaks for your help
Greg
A10ECGent is offline   Reply With Quote
Old 05-03-2010, 04:23 PM   #2
A10ECGent
Re: Needle bearing in oil pan
Well I found the source of the needle bearings. #1 intake lifter had the roller sieze then the cam lobe wore the roller away until the needles dropped out of it. now I'm looking for a cam too. anybody close to Gray, TN got one.
Old 05-04-2010, 05:27 PM   #3
Jrs3800
I have neither.... But I will say this is the first time i have heard of this happening on a 3800 TPI motor...
Jrs3800 is offline   Reply With Quote
Old 05-05-2010, 08:48 AM   #4
LMP
LMP's Avatar
JRS3800, what is the original type? solid or roller ?
What does TPI stand for ?
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
LMP is offline   Reply With Quote
Old 05-05-2010, 04:47 PM   #5
Jrs3800
TPI is Tuned Port Injection..
and the lifter is a Hydraulic Roller Lifter... I have pretty much never seen this happen to a GM roller lifter or a roller lifter in general..
