Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 03-31-2010, 06:36 PM   #1
jayeli
"Woosh", or vaccuum sound...
i have a 00 bravada with 78k. recently i've noticed that only while the engine is running, there is a variable "woosh", (like shhhhhhhhh...) or possible vaccuum sound coming from down near the pedals. it changes as i accelerate or coast. when i turn the engine off, it does a short "woosh", then stops, even with the key still on. does anyone know what this is and how to fix it? thanks.
jayeli is offline   Reply With Quote
Old 04-01-2010, 09:21 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: "Woosh", or vaccuum sound...
Look under there for a vacuum line off.
Does brakes still work good?
If no vacuum line off plug big vacuum hose to brake booster and see if you still hear it.
MT
Old 04-05-2010, 06:45 PM   #3
jayeli
The vehicle is running great, other than this annoying sound. I'm going to check it out again.
What do you mean about plugging a big vacuum hose to the brake booster? Any other suggestions? Thanks.
Old 04-06-2010, 09:52 AM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
If you plug it that will let you know if it is a booster leak.
Tell us if brakes still working good.
MT
