Go Back   Automotive Forums .com Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 03-11-2010, 12:42 AM   #1
tice80j
'93 sunbird won't shift all the time HELP!
At first the car wouldn't shift onto OD so I checked the fluid and it was low. So I added fluid. Now today it did the same, checked fluid and it was fine. After I let off the gas it shifted into OD. Then after making a stop it wouldn't go over 45mph, so I'm guessing 2nd gear. Then after another stop it wouldn't leave 1st gear, finally it went into 2nd but then I was home. What is wrong with it?
tice80j is offline   Reply With Quote
Old 03-20-2010, 01:57 AM   #2
Davez69gto
Re: '93 sunbird won't shift all the time HELP!
This is an interesting problem. So can you get into first when you are at a stop? Does the clutch release? If so is the shifter just stuck? We need a better description to help with this one.
Davez69gto is offline   Reply With Quote
Tags
problems , tranny , transmission
