'01 Cougar No Air flow 99% of the time need heat and live in WI
One day I was driving with the Air on and I went in a store and when I started my car the air was not working. I checked the heat and the different speeds and nothing I had no air flow on any speed or setting. Then one day I happened to try the heat as it was cold out and it worked fine as did the air and everything else. After work the same day it didnt work again. I have been going back and forth with it working and not working and now its been mostly not working last time it worked was like 2 weeks ago. I live in Wisconsin and will need heat and defrost soon. I have called around to see what the dealers and auto stores say and most say it sounds like the Blower motor is bad. I asked about the resistor and they said if that was the case should have some speeds or something still. I know something is working cause when I put my hand in front of the vents i can feel the hot or cold it just doesn't blow. I guess I am asking for any help or ideas. I am also thinking of trying the motor I can get one for around $50 but I have no clue where it is on the car or how to replace shops want about $300 plus what ever to test it to much for me. I tried to find repair info on line but have found nothing can't even find a repair book for this car. any help would be appericated
thanks
Looking for ideas on no air flow
Looking for description on how to replace blower motor pictures would be helpful to.
