Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > C/K
Old 02-13-2010, 10:57 PM   #1
briang0
Turn signal makes wipers go
I have a 94 Silverado 4x4 with a 5.7l v8. This morning I went for a ride and every time I use the left directional my wipers will go also the left directional is blinking very fast and the high beam indicator in the dash lights too. The other issue I have is when I turn on the head lights they do not light and the wiper move then too. If I use the right directional every thing is ok but I still don't have head lights low or high beam. Any ideas?
briang0 is offline   Reply With Quote
Old 02-14-2010, 07:37 PM   #2
briang0
Re: Turn signal makes wipers go
I figured it out this afternoon. It turned out to be a bad ground. Repaired the ground and all the problems went away. Not before I checked all the connections in the front and also in the steering column. I disconnected and reconnected the multifunction turn signal connection as well as the wiper and high beam connections. I removed the auxilary battery tray and found the loose ground wire under it. Case solved.
Old 02-14-2010, 08:02 PM   #3
j cAT
great troubleshooting ! the pro's would have cost you big time on this one !
remember anytime multiple circuits go crazy its normally a bad ground ..also on any vehicle in the rust belt 10yrs old all these ground points need cleaning and securing...
good luck
