Go Back   Automotive Forums .com Car Chat > Citroen > Xsara | Xsara Picasso
Old 09-11-2009, 04:48 AM   #1
Jered89
Jered89's Avatar
Xsara cooling fan/engine overheat solution
I had this problem a couple of weeks ago.
The lights on the dash say "STOP" and there is a light on the thermostat when the engine gets to 97ºC and the main fan cuts in, you pull over, it stops saying "STOP" and then comes back just after you pull away again.
solution:
the rheostat for the secondary fan is broken, they're about £7-8. You need to open the bonnet, with a star screwdriver take the front plastic panel off, and to the left of the center there are 2 connectors. Take out the leads (remember which way round they go) and undo the bolts so the plug comes out. it is a metal 'U' shape, with a spring and a resistor inside. This part needs to be replaced.
If this happens to you, put the aircon on until you reach where you're going.
Jered89 is offline   Reply With Quote
Old 01-12-2010, 08:21 PM   #2
AusRx4
Re: Xsara cooling fan/engine overheat solution
Jered, are the fans working OK now?
The problem is in your diagnosis....the fans in a Xsara if the twin fan system are the same as for a Peugeot 306, where both fans operate all the time and go to high speed when the car reaches 97*c or the a/c is on.
here's a link to the explanation.
Cheers
cooling fans explained....
http://www.peugeotlogic.com/workshop/base/workshop.htm
AusRx4 is offline   Reply With Quote
