| F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750. |
Hello
I have a E-250 (I know this forum is for F series, but should be the same) 2008 with 145,000 Kms. 4.6 L. The thing that is happening is that the transmission is acting weird, when I put reverse it goes but seems like is on reverse and drive at the same time, it won't go back or forward, when give gas goes on reverse but seems like applying the brakes or like it is on Drive intermittent, or shifting from reverse to drive by itself. Any help will be appreciated. Thank you |
Re: E-250 Transmission question
I'm not quite sure what you're saying. But it sounds like your parking pawl may not be releasing, something is broken in the park gear linkage inside the transmission. I have seen this happen on older model automatic transmissions.
Can the van be rolled if put in neutral? If not, it may be the parking prawl like mechhound said. If it does move in that case, it might be the MLPS sensor which is on the driver side of the transmission housing.
![]() 2000 Mercury Grand Marquis LS - 119k / 14.89s @ 92.11MPH [ pictures | videos ] > Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok > Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB > BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms > CVPI aluminum driveshaft |
I took the van to 2 transmission shops today and both gave me the same information "Transmission has a bad bearing and needs to be rebuilt"
Now has a humming noise and worst every minute. Thank you guys but on Monday goes to the shop, bad luck to have a problem with an 2008 van, and is out of warranty because it has 145,000 Kms. and the warranty is only to 100,000 Kms. |
#5 | ||
![]() Join Date: Dec 2008
"Saving the World......One Ford Truck at a Time!" Last edited by dfordski; 01-09-2010 at 08:57 PM. |
