Go Back   Automotive Forums .com Car Chat > Chevrolet > Venture
Old 12-14-2009, 11:59 PM   #1
Cressidaadr
Problems Jump Starting with the Venture
With the cold snap I had to take the Venture out to rescue my wife when her car failed to start in a parking lot. This was my first time to try and connect jumper cables with this van and since the battery is buried you cannot connect directly to it.
I found the remote positive post and just barely was able to get a good connection there since this connection point is too small for my standard cable ends. But the main problem is how do you find a good ground connection. I tried several bolts, the radiator cap, the motor mount arm and all seem to have high resistance.
I eventually got the other car started but it took much longer than it should if one was able to connect directly to the battery post.
The next day I did see one ground connection on the fender but it is half way under the wiper covering and very small so I don't think the cable end will grip it very well.
Anyone else noticed this or where did you end up connecting your ground when jumping?
Cressidaadr is offline   Reply With Quote
Old 12-16-2009, 04:42 PM   #2
henry10
Re: Problems Jump Starting with the Venture
I am new owner of a 99 Venture and tried to jump start the vehicle as well. According to Venture's Owner's Manual, the negative should be connected to an engine part. However, I wasn't able to jump-start it after a few tries and did not persist.
I used to own an 92 Oldsmibile 88 Royale and remember that jumping-starting that as well was next to impossible. I found that recharging its own battery, and having clean battery connections was the best way to start it.
henry10 is offline   Reply With Quote
