Old 12-10-2009, 10:14 AM
chevymank15 chevymank15 is offline
Spindle nut torque spec
Hey everyone I need the spindle nut torque spec, I torqued it to 150ft lbs last night and did some looking around online and I've seen some places say 155-210 ft lbs I'm hoping one of y'all can give me the right torque.
1998 K1500 Z71
5.7L Vin R
Thanks
Old 12-10-2009, 10:22 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Spindle nut torque spec
1998 K1500 Z71
5.7L Vin R
Thanks
Mitch on demand says 165 ft lbs.
Was you replacing the bearing?
MT
Old 12-10-2009, 10:29 AM
I basically rebuilt the whole front end. Brake pads, rotors, passenger side half shaft, seals and bearings in front diff, and both hubs. I'd like to think she's ready for another 200,000.
Old 12-10-2009, 10:35 AM
MT-2500's Avatar
AF - Advisor
Sounds good.
The new wheel bearing usually have the axel nut torque specs in instruction sheet.
And do not forget to torque the axel lug nuts.
Good luck
MT
Old 12-10-2009, 11:43 AM
I got the hub assemblies from O' Reilly's and they was nothin in the box which I felt was odd, But it did have a big sticker on top the box sayin do not use impact as a torque wrench...lol
If you have the axle lug torque I'd take it I just put them as tight as I could with a wrench
Old 12-10-2009, 11:57 AM
MT-2500's Avatar
AF - Advisor
I show 125 ft lbs.
http://www.discounttire.com/dtcs/inf...062!NONE#honda
MT
Old 12-10-2009, 05:59 PM
j cAT j cAT is offline
on the 2000 silverado/tahoe the spindle [hub] nut is listed as 155ft lbs..
I would say your good...
I would put some med lock tight on the nut if it is not new nut..
Old 12-10-2009, 06:15 PM
6 and 8 wheel lug nut is listed as 140 ft lbs...I usually torque to 110ft lbs . then repeat after driving for a day...
