Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 12-10-2009, 12:55 PM
venturenot venturenot is offline
Cost to replace the O ring on oil pump drive shaft
Any one know the cost to repair the O ring on the Oil pump drive shaft. Is it a difficult job?
Thanks
Old 12-10-2009, 05:24 PM
kornjulio kornjulio is offline
Re: Cost to replace the O ring on oil pump drive shaft
I replaced the o-ring when I did the LIM - it was right there, so there was no reason not to. However, if you're doing just the o-ring; you may be able to get at it by just removing the throttle body from the upper manifold. Remove the clamp bolt and with a pair of channel-locks pull the drive straight up.
Obviously the part is relatively inexpensive from a GM dealer.
2000 Venture - repairs to date:
LIM gasket, water pump, wiper park position, front wheel bearings, rear wheel bearings, flickering lights, blower motor resistor, door speaker corroded, rear hatch handle, rear wiper motor, front struts, busted sway bar, LCA bushings, hard shifting tranny (new solenoids!)
