Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-08-2009, 04:44 PM
pepp pepp is offline
AF Premium User
can I use my same rings ?
hey guys, I have a question, I have to replace #3 piston and block is ok so i went to junk yard and pulled a piston out of another motor, now i do have a new rod bearing but cant find rings for just one piston so can i use same rings? do you think they will reseat and be ok?
Old 11-08-2009, 05:10 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: can I use my same rings ?
How many miles are on these rings? If you had good compression before then they should seal back fine.
If the motor hasn't been rebuilt before I would recommend to go ahead and replace all the rings while your in there. It wouldn't take long to do a quick hone and rering it. Also some new bearings and you would be good to go.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-08-2009, 07:13 PM
AF Premium User
Thanks for the reply but the car is onley a stanby incase we have a breakdown not worth that much, but it does or did run good ,piston & rod onley cost $16. new rod bearing $6. head gasket 18 bucks just wondered about those rings. shoud i knock the glaze off the rings aswell as the block u think ?
Old 11-08-2009, 10:26 PM
Holset powered 420a
If its just a backup car I would just put them back in, I just recently had to replace a bent rod and I reused the rings and they sealed back perfectly. They only had 15k so I wasn't worried about it to much. I wouldn't touch the rings or cylinder walls just put them back in. Worst happens they dont seal up as good as before but I doubt it would be bad enough to hurt anything
98 Eclipse GS Turbo
2001 BMW 325i - DD
