Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-25-2009, 09:32 PM   #1
chandr
Question Battery is discharging very fastly
Hi,
I am having the 1998 Toyota Camry XLE V6. Last year I have changed the starter contacts. This year the battery is discharging very fast and unable to start the car in the morning. This issue starts when the temperatures are coming down.I want to know what I have to do to fix this issue.
Thank You,
Chand
chandr is offline   Reply With Quote
Old 10-26-2009, 10:00 AM   #2
Mike Gerber
AF -Advisor
Re: Battery is discharging very fastly
Jump start the car and drive it to one of the auto parts stores in your area that offer free testing of the battery and alternator for free, while still on the car. First, call around to the auto parts stores in your area and ask if they offer this free service. This should tell you what is wrong and what needs to be replaced.
Mike
Mike Gerber is offline   Reply With Quote
Old 10-28-2009, 02:44 PM   #3
jdmccright
The RustBuster
jdmccright's Avatar
As suggested, it may simply be an old battery...any one older than 4 to 5 years is running on borrowed time regardless of the warranty. Get it load tested and see if its due for replacement. Hopefully you'll have the receipt for the old one to get the proper pro rata credit towards the new one, if the warranty allows it. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
jdmccright is offline   Reply With Quote
Old 10-28-2009, 07:53 PM   #4
RIP
AF -Advisor
RIP's Avatar
Happy to see that you changed the starter contacts instead of the starter. It's about the only thing that goes bad in a starter. Installing a new starter in most cases is overkill.
If the battery passes a load test and isn't ancient, you may have what is called a parasitic power drain. Here's how to check it out: http://www.ricksfreeautorepairadvice...-battery-drain
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
RIP is offline   Reply With Quote
Old 10-29-2009, 05:28 AM   #5
hittmann81
I've had similar problems in the past and i think it could be the carbon brushes in the back of the alternator. Shouldn't cost too much to replace those. You can also test the voltage at the terminals while the car is running.
hittmann81 is offline   Reply With Quote
