Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 11-09-2009, 05:44 PM   #1
JOEYD0730
94 safari electrical problem
94 safari awd
having a strange problem on my 94 safari ext awd. its intermittent. while driving if you turn on iterior light or hit horn the van stumbles and sometimes stalls. radio will cut off then eveything comes back on. voltage is good at alt seems to be charging. its starting to do it without turning interior lights on.. any suggestions? no fuses blowing, i know the horn and lights and radio are on same circuit. thanks for any insight, joe
JOEYD0730 is offline   Reply With Quote
Old 11-09-2009, 06:29 PM   #2
old_master
Advisor/Moderator
old_master's Avatar
Re: 94 safari electrical problem
Most likely either a poor ground, possibly a bad body ground, or poor power connection. Charging voltage with the engine running and all accesories turned off should be 14.2 VDC. There is a known problem area under the underhood fuse panel. Fusible links tend to corrode and can cause problems such as yours. If you have questions, just ask. Keep us posted with progress.
You have to know how it works,
to figure out why it doesn't.
old_master is offline   Reply With Quote
Old 11-10-2009, 05:51 PM   #3
JOEYD0730
probel solved, you called it, one of the prongs in the 4 prong power clip melted behing the battery that goes through firewall. the clip with 4 orange wires. just cut the bad one out and re-powered it off the battery, all seems weel now, thanks a million
