Turn signal stalk removal, GM steering column.
Can someone remind me if the stalk simply pulls out or if it unscrews.
It's a 1984 Jeep Cherokee which uses a typical 1980's-era General Motors steering column, The stalk has washer and wiper controls at the tip, but no cruise control. A friend has accidentally snapped the old lever off. The remains of the broken shaft is flush with the housing, so I will have to drill it and use an easy-out or something to remove it.... unless someone has a better solution?? Thank you |
Re: Turn signal stalk removal, GM steering column.
I dunno, but if you can find the replacement part you can look at how it attaches to the column. My guess would be that it is held in there with a pin or set screw.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. Last edited by jdmccright; 10-22-2009 at 10:28 AM. Reason: Added info |
most of those press in. drill a hole down the center of the remaining piece stuck. then take the back side of a cheap drill bit or tiny nail with some super glue on it and shove it in the hole you drilled. then just pull the broke piece out.
thank you for the info.
