Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 12-09-2009, 08:13 PM
DannyBoy1991 DannyBoy1991 is offline
Help with Sol anyone?
Hey my 1993 DelSol Si will run but will not move at all. Its like all the gears are in neutral. Have no idea what is wrong with it because i replaced the clutch so the only other thing i can think of is the tranny. SOOOOO im just gonna buy a new engine and tranny for it. But i would love to know what is really wrong with it before i actually go out and get a new engine and tranny. Thanks!
- Danny
Old 12-28-2009, 01:42 PM
DownToGround DownToGround is offline
Re: Help with Sol anyone?
the secondary shaft likes to break on b series trannys.. ive replaced them many times
Old 02-06-2011, 12:19 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Have you tried putting the car in gear with the engine off? All gears? If you can put it in gear and the car still rolls, Id say your clutch install has a hitch somewhere. Its pretty hard to break a ring or pinion gear on a stock powered car, it takes a few hundred horses to do destruction of that magnitude. It could be that the car isnt getting into gear at all, perhaps because of the linkage, or the selector. You need to try it with the car off, and try rolling it back and forth when its in gear. You will be able to feel the resistance of the gears even if it rolls, which would mean your clutch is not engaging because it is jammed up.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Tags
repair
