Go Back   Automotive Forums .com Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 09-02-2009, 10:27 PM   #1
carl80
70 bug drum brake
i dont know much about bugs. i cant get the drum off. my other cars they just pull off. is there a different way to do these. or do i need to try harder
carl80 is offline   Reply With Quote
Old 09-05-2009, 04:52 PM   #2
BoatCop
BoatCop's Avatar
Re: 70 bug drum brake
You need to remove the bearing retainer nut and bearings on the front axles and loosen/remove the castle nut on the rears.
NOTE: The left front wheel bearing nut is left hand threaded. You must turn the wrench to the RIGHT to loosen and remove it.
The rear axle castle nuts are torqued to around 250 ft/lbs. Use a BIG breaker bar or impact wrench to remove them.
Alan
BoatCop
BoatCop is offline   Reply With Quote
Old 10-10-2009, 11:59 PM   #3
Doug Rodrigues
Send a message via MSN to Doug Rodrigues
re: Putting the rear drums back on. If you don't tighten the castle nuts to 250 ft. lbs, or tighter, the drums will hammer out the axle spleens until you don't have any spleens left
If the rear axle nuts aren't torqued to at least 250 ft. lbs., the axle spleens will be hammered out until there aren't any spleens left? Seen that many times.
Doug Rodrigues is offline   Reply With Quote
