Originally Posted by Hendrix31
The dims quit working (both of them) all of the sudden. I have replaced the light switch assembly in the door as the manual said the only fuse was a blow circuit in that. Please help
I would look at the dimming switch, which I believe is at the bottom of the steering column. When you pull up and down on the turn signal that pulls a link that switches between bright circuit and low beam circuit. I believe, I believe that switch is down on the steering column. You can check to see if voltage is coming out the wires there for the dims.
