96 lumina fuel injectors test
i want to do the ohms test on my injectors.
do i have to take off the tophalf of the manifold to do that?????
Re: 96 lumina fuel injectors test
Yes, how else can you get to the connectors.
you dont have to remove anything
the injector plugs are out in the open unplug and plug back in each one while engine is running to check for bad one a bad one will make no change in how it runs no other real way for a home wrencher to check injectors unless you can do an ohms test if you have an ohmmeter and know the correct specs but even then it doesnt mean they arent plugged or damaged in another way pull some injectors from a spare engine and try them i replace injectors commonly they go bad especially the last two number 5 and 6 it just happens [causes a dead cylinder miss shake in the engine
I also am user fastr68 here- Randy -'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee, |
The resistance test should be made at the injector connector, what you suggest is good for injector to injector comparo only. But it does save extra work.
There is a main connector that you can check from without having to remove the intake or fiddle around under the cramped intake. I'll have to look at a wiring diagram to get the wires to test.
