Go Back   Automotive Forums .com Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-25-2009, 03:44 AM   #1
2003rsxtypes
Exclamation vibration problem need an expert my rsx is falling apart need HELP!!!
ok so it vibrates the whole car ONLY at about 1000 to 2000rpm then is fine up to 8000 it can be in N or any gear clutch engaged or not any speed NO codes tho
engine mounts "seem" ok no clunking or any abnormal engine movement .
car has 100,000 mi 2003 rsx type s
pleas help the vibration is unbearable
does any one know if the k20a2 has a counter balance shaft and can it go bad
thanks in advance for any help
2003rsxtypes is offline   Reply With Quote
Old 09-27-2009, 06:48 PM   #2
somick
somick's Avatar
Re: vibration problem need an expert my rsx is falling apart need HELP!!!
Could a balancer belt brake (if it has one)?
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
somick is offline   Reply With Quote
Tags
civic , honda , repair , rsx , type
