Go Back   Automotive Forums Car Chat > Nissan > Quest | Presage | Serena
Old 07-22-2009, 11:02 PM
perrywu perrywu is offline
95 Quest not shift to gear 4
Not sure why my 95 Quest LOST gear 4....
it runs at gear 3 so make it 3.2k rpm at 60mph.
Run through A/T control self check seems all good.
I have no idea what to do now...
Any suggestion are welcome!! thanks
Old 07-25-2009, 08:17 AM
tempfixit tempfixit is offline
Re: 95 Quest not shift to gear 4
How many miles on vehicle and have you tryed a fluid and filter change? Does shifting it manually from 3rd to OD make a difference? I am thinking that the torque converter is not going into lock up.
Old 08-25-2009, 10:58 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Question Re: 95 Quest not shift to gear 4
I have the same problem - no overdrive and high rpm's on the road ! The fluid and filter was changed recently and it seems to shift better ( although it's still slow going from 1st to 2nd gear . You mentioned shifting it manually from 3rd to Overdrive . There is no OD position on the indicator . There is a button , on the end of the shift lever , to turn OD on and off . When it's turned off , an indicator light on the dash reads " OD off " . The lack of OD really kills the mpg ! Does anyone have a similar experience ? Any and all suggestions will truly be appreciated !
" Sometimes I grow so tired "
