Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 07-26-2009, 12:44 AM
dj juggalo dj juggalo is offline
engine wont turn over
i have a 97 shinoda boss and the fan recently fried....after it did everyday the batt was weaker and weaker now all it does is click repeatedly when i turn the key....had batt and alt tested both are good...figure the batt problem was the bad fan constantly pullin on the batt.....still cant figure out why it wont start...unless i push it off the it runs fine..
Old 11-12-2009, 11:51 PM
OldSVTGuy OldSVTGuy is offline
Re: engine wont turn over
Something is draining the battery. With a multimeter to measure mini-amps (you have to remove one battery cable and attach the meter between the cable and the terminal), remove the fuses one at a time until you get no draw. Electrical gremlins are a realy pain!!
Good luck....
