Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 02-27-2006, 03:48 PM
kkemper kkemper is offline
reset brake light
1995 toyota tacoma how do you reset braek light in dash. i have changed breaks and toped off fluid need to get light off please help.
Old 02-28-2006, 11:10 PM
lh2369 lh2369 is offline
Re: reset brake light
there is no reset light, you have other problems
Old 03-01-2006, 06:05 AM
Flash75 Flash75 is offline
AF - Advisor
Try bleeding the brakes first. If that doesn't work recheck the rear brake initial adjustment and parking brake adjustment outlined in the following link.
http://www.4x4wire.com/toyota/mainte...leedingbrakes/
Clifton
Old 08-02-2009, 04:29 PM
vikkterr vikkterr is offline
I know I'm really late to add to this, but alternatively if you've had brake work done recently and know that the light shouldn't be on, then you can reset it by disconnecting the positive battery cable, depressing the brake for a few seconds to reset the ABS sensor, and then reconnecting the cable. That ought to fix it, I had the same issue after replacing a faulty caliper.
