Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > Camaro Discussions
Old 07-11-2009, 01:50 PM   #1
michael20
95 camaro 3.4l starting and idling issue.
hi im new here. I have a 95 camaro with a 3.4l v6 and it wont start unless i spray starter fluid in it and when it does start it idles at 3000rpms. im not sure why its doing it so i thought id sign up here ask some people with the know how. would really appreciate any info i could get. thks.
michael20 is offline   Reply With Quote
Old 07-12-2009, 12:43 PM   #2
michael20
Re: 95 camaro 3.4l starting and idling issue.
Anyone?
Old 07-12-2009, 01:36 PM   #3
jason-1995fbody
jason-1995fbody's Avatar
will it continue to run on its own once started
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
jason-1995fbody is offline   Reply With Quote
Old 07-12-2009, 01:38 PM   #4
michael20
yeah it will continue to run and the rpms will slowly climb like im have my foot on the gas
Old 07-12-2009, 02:29 PM   #5
michael20
would it be the airflow sensor causing the problem, if so would that also cause it to not start.
Old 07-12-2009, 10:14 PM   #6
jason-1995fbody
95 3.4 didnt have an air flow sensor
start with the basics check the throttle body for something holding it open
also have the engine codes checked
reset the iac, hold the gas pedal to the floor and crank the car for about 30 seconds then try starting the car
Old 07-12-2009, 11:32 PM   #7
michael20
i found a hose piece that was split so it was a vaccum issue i guess but cant figure out why it wont start on its own, its sounds like its trying to turn over
Old 07-13-2009, 04:51 PM   #8
michael20
well i was wrong about that 2 to 1 hose piece being the problem, still idles at 3000 rpms, and still wont start on its own and i cant get it up to a shop to get the car scanned and figure out the problem. it starts up fine if i spray starter fluid in it, but not if i try to crank it without it.
Old 07-13-2009, 06:47 PM   #9
jason-1995fbody
get a hains manual and start checking things like the tps map sensor and so on
Old 07-13-2009, 10:41 PM   #10
michael20
ok thks.
Old 07-26-2009, 11:02 AM   #11
instantkevin
instantkevin's Avatar
Send a message via Yahoo to instantkevin
that's the right direction. though, it sounds to me like somebody set the idle real high to keep it running (i.e. cover up some other problem). with it set too high, it would have the same effect as trying to start the car with your foot on the gas (too much air). find the idle adjustment screw and back it out 7-8 turns. see if that helps. if not start it with the fluid again and see where it idles. keep backing the screw out until you get to ~1000rpms.
throttle position sensor could be bad or installed wrong (or not connected).
also a Idle Air Control valve (IAC) that is stuck (internals not moving properly) could prevent the car from starting. this generally can be fixed by taking the internal parts out, smoothing them out with sandpaper, doing the same to the bore, and adding some lubricant to the spring and everything else.
very likely, your problem is with one of these three items.
any check engine light on, while it's running?
if so, reset it by unplugging the batter for 10mins, then see if the light comes back.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
instantkevin is offline   Reply With Quote
