Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 06-24-2009, 02:04 PM   #1
jmull256
05 silv both fan fuses blown
it was a normal hot fl day sitting in drive through i noticed a very strong electrical burning smell and neither fan was on even with ac running and temp way above norm it cooled off after very short time driving and when home i discovered both fuses blown i replaced and seems ok for now but i cant figure why both fuses would blow together or at all for that matter the truck has just under 55000 miles and has always worked fine
jmull256 is offline   Reply With Quote
Old 06-24-2009, 05:21 PM   #2
j cAT
Re: 05 silv both fan fuses blown
what are you talking about radiator fans..?
Old 06-24-2009, 07:00 PM   #3
jmull256
yes radiator/cooling fans
Old 06-24-2009, 07:52 PM   #4
j cAT
from the fuse box to the fan mounting area the wires will follow a common path,,,inspect the wires for damage...was this vehicle accident damaged/body repair etc..
Old 06-24-2009, 08:02 PM   #5
jmull256
ohm tested wiring between fuse block and fans checked out ok fans run fine when connected to bat+ individually vehicle has never been wrecked as i have owned it since new everything i can think to check is working normal i just think blowing 2 40 amp maxi fuses at same time along with the smell is odd and i cant figure it out i have also pulled the wires out of the wrap and inspected visually with no signs of damage to wires or connectors
Old 06-24-2009, 08:17 PM   #6
j cAT
I would inspect under the fuse box...
disconnect connectors for damage/corrosion
Tags
fans , fuses , overheat
