WTB 650 injectors
Anyone have a set lying around there looking to part with?
![]() Join Date: Mar 2004
Re: WTB 550 injectors
Based on your DSMLink thread, you might want to look into something larger than 550's. You can easily max out 550's with a 16g depending on the boost and airflow you're pushing. Just a thought.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Are you thinking 650s?
good thing about link is you can put anything in there! So whatever you can find!
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
hoenstly though Id say wideband o2 first before injectors even though your IDC's are maxed you might be able to lean it out a bit and squeeze those injectors a bit more. PLus right now you have no idea your actuall a/f ratios.
#6 | ||
![]() Join Date: Jun 2002
-Brian
#7 | |
Holset powered 420a
Deffinately go with 650s. Will be perfect for a 16g setup.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
#8 | |
I'll look into the 650s.
#9 | |
Are there any cars at the junk yard that I can pull 650s out of that will work in my car?
#10 | |
650's as stock injectors I don[t think so.
#11 | |
Damn, trying to find a cheap set. No luck so far, found a set of 550s on ebay for RCs but auction hasn't ended yet.
#12 | |
#13 | |
Holset powered 420a
Yea those look good
#14 | |
In a week or so I will either be able to get the WBO2 or those injectors, I think it would be wise to get the WB 1st.
#15 | |
Will a Moderator change the title to this thread
"WTB 650 injectors" Thanks, still looking. EDIT:If I could get my hands on some RC 1000cc injectors for the right price, would it be too much over kill? W/ link I can do the proper adjustments, would it be a good idea? Last edited by ned032002; 06-18-2009 at 11:35 PM. |
