Old 06-08-2009, 02:10 PM   #1
rabbitthief
Stalls and studders
2004 Cavalier
I started my car this morning and it has been vibrating huge friction from the front of the car, while idle or braking my cars rpms jump from 500 to 1500 i could feel vibration in my foot from the brake pedal and when i drove it around the block it stalled twice when i braked giving me a "Battery Charging System" light and a "Engine Oil Pressue" light took about 10seconds to get it started again, i see no signs of overheating, i let the car just sit and run and has never done over the normal temps i see
its a 2.2L ECOTEC engine. I use a 10,000 mile oil change method from belle tire, but the oil seems to be darker than its suppose to and i'm 3,000 mile from scheduled oil change. could it just be an oil change or more to it than that?
rabbitthief is offline   Reply With Quote
Old 06-08-2009, 09:24 PM   #2
J-Ri
J-Ri's Avatar
Re: Stalls and studders
Check for codes. If a car runs bad, it should not be driven or even allowed to run. Period. The only exception to that does not apply to anyone asking questions here, and requires training and $5,000 of diagnostic equipment in the car with you. If you don't have or won't buy a code reader, have it towed to a shop or you will damage the engine. If it's easier, remove the ignition module and have it tested at an auto parts store. It sounds like that could be the problem.
The oil and charging lights will come on any time the engine dies because the oil pump and alternator both stop turning.
10,000 miles is way too much, no matter how "good" the oil is. Before I installed a supercharger on mine, I changed the oil with full synthetic every 5k miles, now I change it every 3k. Both of those include 12oz of a high quality additive package, not cleaners and such, but the additives that the oil companies already add to make the base oil last longer. Change the oil while you're thinking about it, and from now on, change it as soon as it turns a light almost rusty color. That may be 2k miles for a while, until the clean oil cleans the engine out. I had to change mine every 2k for the first couple changes after I bought it, but I was able to go to 5k after it was cleaned out. Don't add cleaners to speed up the cleaning either, they are terrible for the bearings. There is no engine that runs clean enough to change the oil at 10k miles.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
J-Ri is offline   Reply With Quote
