Go Back   Automotive Forums Car Chat > Buick > LeSabre
Old 10-01-2002, 01:15 PM
Webb Webb is offline
Engine Stalls randomly without warning
I have a 1987 Buick LeSabre and I will be driving down the road and all of a sudden the car will just stop, no power at all. I get the service engine soon light that comes up on the dash along with the oil and battery light that comes on too (just as if was on aux).
I have had times that the engine does keep running but the service engine soon light pops on.
I pull over, shut the car off and start it right back up and it runs fine until the next time it happens.
This happens with a full tank of gas, low on gas, running for 1 hour, running for 10 minutes.
I have checked the computer for codes but I never seem to have one stored.
Checked Fuel pressure and it is fine at cold start and running for awhile.
Coil and ECM have been replaced.
Throttle Position Sensor has been replaced.
Computer has been replaced.
Plugs and wires have been replaced.
HELP!!!!
Old 10-16-2002, 10:58 PM
joshey joshey is offline
it might be your camshaft position sensor magnet it wears out and falls into your oil pan. check that it will cause it to stall when you let off the gas. or a loose battery connection, because the car will not run without a batery.
Old 10-31-2002, 05:23 PM
Thank you so much for your reply. It wasn't the camshaft sensor but you did put me on the right track.
It has been about 2 weeks now without any trouble. I changed the crankshaft sensor. It runs a little rough still and I'm still working on that but no stalls.
Thanks again for the help..............
Old 05-13-2009, 07:55 AM
lilaclove lilaclove is offline
Re: Engine Stalls randomly without warning
I had the same problem with my 95 buick le sabre.. I was told it was the crank shaft sensor. i replaced that and it still stalled. so i stopped using my cruise control and then i had no problem with her unless she was extremly cold.
Old 06-02-2009, 01:26 PM
Andreas E.'s Avatar
Andreas E. Andreas E. is offline
Hi all!
I have recently had a similar problemon my 92 Lesabre, but only after driving for a longer period of time, say at least 45min to an hour. I replaced the fuel filter (had the same problem many years ago with a different vehicle) and it's still doing the same. It happens intermittently. Most of the time it runs just fine, cruise or no cruise, hot or cold. A couple of days ago it was really bad for several miles, but then it just returned to normal. Since I was going at freeway speed, the engine stalled but came right back to life. I was once at a light and it just went dead but started right back up again as if nothing happened. I have about 163k miles on it. Could it be the camshaft magnet as well? I've read about it before. It seems it's just glued on? How difficult is it to fix? I do most of the maintenance on the vehicle myself.
Old 06-04-2009, 08:51 PM
stuzman stuzman is offline
WOW! I wonder if Webb got his car fixed after seven years has passed.
Old 06-05-2009, 10:30 AM
Andreas E.'s Avatar
Oops, sorry, I did not realize the original post was that old. I just added to a recent dig, I guess. Mea culpa. I know the rules...
97 talon engine stalls randomly without dying altogether analogkidd1 Eclipse Problem Diagnosis 1 10-05-2009 01:41 PM
Re: Engine Stalls randomly without warning - Redux meldoug2188 LeSabre 2 06-29-2009 09:56 AM
97 lumina engine acting erratically. aptivaa12 Lumina 5 04-22-2009 10:42 PM
94 Regal dies without warning and does not start/95 LeSabre dies without warning II mariley Park Avenue 0 07-29-2006 12:22 PM
Car Stalls without warning but restarts after, please any help would be great zerowipeout Accord/TSX/Accord Hybrid 12 09-08-2005 11:25 AM
