Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 06-11-2009, 08:33 PM   #1
kason
Exclamation gas/oil in with plugs after change??? help
i own a 95' sohc 2.0 auto
1. after a recent plug and wire change gas/oil moister gets in the plug tubes i dont think its a cracked head ??? but i dont know please help. would it have anything to do with the new plugs or wires?
2.ive had the car for about 3 years without any major prob but has always shifted kind of hard from 1st to 2nd but smooth the rest of the way up and back down anyone have the same prob. they fixed
any help would be appreciated thanks....
kason is offline   Reply With Quote
Old 06-11-2009, 08:37 PM   #2
kason
ohh it has 129,323 miles on it also if i turn the steering wheel when im not going at lest 5mph it makes a loud sqweel any ideas on this would help has also done this since i got.
Old 06-12-2009, 07:51 AM   #3
Oldsmobile Doctor
Re: gas/oil in with plugs after change??? help
The spark plug tubes can leak oil where they press into the head and around the seals to the valve cover. Remove the valve cover and replace the seals and gasket. While it is off check for the tubes being loose. if so remove , clean and replace with locktite or some other hardening sealer. The first gen neons had a problem with the power steering - AC belt not staying tight if it is loose it will squeal. New belt and get it as tight as you can, I have found taking the water outlet off helps with getting to it.
Oldsmobile Doctor is offline   Reply With Quote
Old 06-12-2009, 07:58 AM   #4
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
As far as the shifting, I would assume this is an automatic you are talking about, if so, then check the fluid level. It may be time for a new filter and fluid as well. The Chrysler transmissions are sensitive about what fluid you use, so make sure you ONLY use ATF+4!
2003 Dodge SRT-4
das2123 is offline   Reply With Quote
Old 06-13-2009, 12:04 PM   #5
kason
ok so i have to take the top of the engine off and change the seals/ gasket is it a pretty easy, cheap job? do i need any kind of hardener for when i re-seal the head? is there any way you may beable to walk me through a few of the steps and what parts/ tools will i need ive seen it done before but dont want to make anything worse . thanks for the help and how hard would it be to change my timing belt would i beable to do it my self?
Old 06-14-2009, 12:42 PM   #6
Oldsmobile Doctor
Don't need to take the head off just the valve cover
