Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 06-04-2009, 08:38 AM   #1
lesam1
Wink 99 Bravada air recirculation not working
Hello, we have a 99 bravada and the recirculation button does not seem to be working anymore, the light comes on when the button is pushed, just no increase in air. It used to increase the fan speed and really blow the air but now it does not do anything. A while ago you could hear a sucking sound when any type of air was on – I have not heard this for a while now(this may be another problem altogether). After reading some of the other posts the only thing I found similar was the blend door problems (of course they were only blowing hot air when cold air was needed). What should be checked or taken apart to fix this? Does anyone have pics of the procedure?
lesam1 is offline   Reply With Quote
Old 06-05-2009, 09:43 AM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: 99 Bravada air recirculation not working
There's a door, like the blend door, under the glovebox that opens to recirculate the interior air. It's operated by engine vacuum so you might check for a cracked or broken vacuum line.
Chris Stewart is offline   Reply With Quote
Tags
climate , recirculation , vacuum
